跳转到主内容
Garmin Nuvi 2689LMT Screen Replacement
你所需要的
  1. Garmin Nuvi 2689LMT Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove the stand by depressing the tab and rocking the round interface back away from the tab, pulling it away from the Garmin unit.
  2. Garmin Nuvi 2689LMT Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the four 4mm hex screws from the four corners of the unit using a T5 bit.
  3. Garmin Nuvi 2689LMT Screen Replacement: 步骤 3 中的图像 1,1
    • Place the unit screen-side down flat, with the bottom facing you. There are two seams; the one on top is artificial.
    • This is the real seam—open it with a plastic opening tool in step 4.
  4. Garmin Nuvi 2689LMT Screen Replacement: 步骤 4 中的图像 1,1
    • Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the tool into the unit until you feel a click.
    • Repeat this all the way around the seam.
  5. Garmin Nuvi 2689LMT Screen Replacement: 步骤 5 中的图像 1,3 Garmin Nuvi 2689LMT Screen Replacement: 步骤 5 中的图像 2,3 Garmin Nuvi 2689LMT Screen Replacement: 步骤 5 中的图像 3,3
    • Do not attempt to separate the unit until all the tabs have been separated. Once the seam is completely separated, you can lift the back away from the screen easily.
  6. Garmin Nuvi 2689LMT Screen Replacement: 步骤 6 中的图像 1,1
    • Retrieve a new screen and connect the flat-gold wire to the socket from where you removed the old screen.
结论
2等其他人完成本指南。
Spencer
于09/26/16注册
273 声望
创作了2篇指南
团队
USF Tampa, Team 16-5, Eyestone Fall 2016 USF Tampa, Team 16-5, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G5
3 名成员
创作了5篇指南
2条评论
Were can I order a 6 inch screen for a Garmin Nuvi 2689 LMT
James Fraley - 回复
The screws will not come out. I have the screwdriver that was sent with replacement screen. Help!!
debbie_reeves - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,267
