跳转到主内容
Garmin Nuvi 2689LMT Main Circuit Board Replacement
你所需要的
  1. Garmin Nuvi 2689LMT Main Circuit Board Replacement, Main Circuit Board: 步骤 1 中的图像 1,1
    • Begin by removing the stand by depressing the tab and rocking the round interface back toward you, pulling it away from the Garmin unit.
  2. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Remove the four, 4mm hex screws at the four corners of the device using a T5 bit.
  3. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Place the unit screen-side down flat, with the bottom facing you. There are two seams, the one on top is artificial.
    • Pry open the seam with a prying tool.
  4. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the spudger into the unit.
    • Repeat this all the way around the seam.
  5. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Do not attempt to separate the unit until all the tabs have been separated. Once the seam is completely separated, you can lift the back away from the screen easily.
  6. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 6 中的图像 1,1
    • The battery is connected to the main circuit board via two wires, red and green in color, and is attached with a white connector.
    • Detach with a pry tool.
  7. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 7 中的图像 1,1
    • The white battery is attached to the casing with an adhesive. Separate it with a prying tool.
    • Removing the battery protects it from damage and gives you more room to work.
  8. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 8 中的图像 1,2 Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 8 中的图像 2,2
    • Remove the four, 4mm hex screws with a T5 bit.
    • These are located near the four corners of the main circuit board, as shown.
  9. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 9 中的图像 1,1
    • Carefully pick up and remove the main circuit board from the device’s plastic casing.
  10. Garmin Nuvi 2689LMT Main Circuit Board Replacement: 步骤 10 中的图像 1,1
    • Remove the speaker - located on the device as shown - from the plastic casing using a prying tool. Use the prying tool around the entire rim of the speaker to ensure a clean removal.
结论
To reassemble your device, follow these instructions in reverse order, using a new circuit board.
Spencer
于09/26/16注册
273 声望
创作了2篇指南
团队
USF Tampa, Team 16-5, Eyestone Fall 2016 USF Tampa, Team 16-5, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 575
