跳转到主内容
Garmin Nuvi 265WT Screen Replacement
你所需要的
  1. Garmin Nuvi 265WT Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove PN/Model sticker an the lower side of the device.
    • Use pentalobe screwdriver to remove the two screws underneath it.
    • Use the nylon spudger to remove the screen from the device.
    • The regular black nylon spudger should be used whenever possible, especially around glass displays and other sensitive components.
  2. Garmin Nuvi 265WT Screen Replacement: 步骤 2 中的图像 1,1
    • Lift up the screen gently and place it on the opposite side.
  3. Garmin Nuvi 265WT Screen Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to gently lift up the white rectangular snap clip that is attached to the screen.
  4. Garmin Nuvi 265WT Screen Replacement: 步骤 4 中的图像 1,1
    • Lift up the screen and you're done.
结论
团队
Texas Tech, Team 6-4, Bennett Fall 2016 Texas Tech, Team 6-4, Bennett Fall 2016 的会员
TTU-BENNETT-F16S6G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 466
