跳转到主内容
Garmin Nuvi 260W Screen Replacement
你所需要的
  1. Garmin Nuvi 260W Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Carefully remove model/serial number sticker.
  2. Garmin Nuvi 260W Screen Replacement: 步骤 2 中的图像 1,1
    • Remove two 4mm T5 Torx screws located under the sticker.
  3. Garmin Nuvi 260W Screen Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 260W Screen Replacement: 步骤 3 中的图像 2,2
    • Once the screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
  4. Garmin Nuvi 260W Screen Replacement: 步骤 4 中的图像 1,1
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
  5. Garmin Nuvi 260W Screen Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to loosen the three clips located on the top of the screen encasing to a position that loosens the hold on the screen.
  6. Garmin Nuvi 260W Screen Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to loosen the two clips on the short sides of the Nuvi screen encasing to a position that allows the removal of the screen.
结论
Hunter Johnson
于03/27/18注册
327 声望
创作了2篇指南
团队
IUPUI, Team S3-G5, Harley Spring 2018 IUPUI, Team S3-G5, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S3G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 311
