跳转到主内容
Garmin Nuvi 260W Circuit Board Replacement
你所需要的
  1. Garmin Nuvi 260W Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Carefully remove model/serial number sticker.
  2. Garmin Nuvi 260W Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Remove two 4mm T5 Torx screws located under the sticker.
  3. Garmin Nuvi 260W Circuit Board Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 260W Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Once screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
  4. Garmin Nuvi 260W Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
  5. Garmin Nuvi 260W Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Once the body of the nüvi is separated and the ribbon cable is disconnected, remove the three 1.6mm Phillips #0 screws.
  6. Garmin Nuvi 260W Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Carefully disconnect the two cables connecting the battery to the motherboard and remove motherboard.
结论
另外一个人完成了本指南。
Hunter Johnson
于03/27/18注册
327 声望
创作了2篇指南
团队
IUPUI, Team S3-G5, Harley Spring 2018 IUPUI, Team S3-G5, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S3G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 452
