跳转到主内容
Garmin Nuvi 2597LMT LCD Replacement
你所需要的
  1. Garmin Nuvi 2597LMT LCD Replacement, LCD: 步骤 1 中的图像 1,2 Garmin Nuvi 2597LMT LCD Replacement, LCD: 步骤 1 中的图像 2,2
    • Turn your device over so the back is revealed and you can see the screws in the four corners.
    • Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
  2. Garmin Nuvi 2597LMT LCD Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 2597LMT LCD Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along all sides if need be.
    • Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable as well.
  3. Garmin Nuvi 2597LMT LCD Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 2597LMT LCD Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 2597LMT LCD Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use your tweezers to flip back the tab of the ZIF (Zero Insertion Force) Connector, that is used to keep the ribbon cable in place.
    • This releases the ribbon cable separating the two halves of the device.
  4. Garmin Nuvi 2597LMT LCD Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 2597LMT LCD Replacement: 步骤 4 中的图像 2,2
    • Use your hands to pull back the clips that hold the LCD in place.
    • Once you have removed the LCD you can safely set it aside.
结论
3等其他人完成本指南。
Patrick McNett
于10/03/16注册
887 声望
创作了5篇指南
团队
USF Tampa, Team 1-4, Sullivan Fall 2016 USF Tampa, Team 1-4, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S1G4
4 名成员
创作了5篇指南
一条评论
Where can I get this replacement screen?
Anand Geetey - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 21
总计 1,696
