跳转到主内容
Garmin Nuvi 2595LMT LCD Screen Replacement
你所需要的
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: 步骤 1 中的图像 1,1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 2595LMT LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 2595LMT LCD Screen Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 2595LMT LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,2 Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,2
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: 步骤 5 中的图像 1,2 Garmin Nuvi 2595LMT LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Place new screen in proper position, with the ribbon facing downward.
结论
2等其他人完成本指南。
3条评论
cannot prise open the connector to replace ribbon
norman bayne - 回复
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - 回复
Re-seating the ribbon is simply impossible.
daBee - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 4,608
