简介
Replace a cracked or malfunctioning display/touch screen to your Garmin NUVI 2589LMT device. Replacing the the display screen requires careful attention to detail, but requires a small amount of time.
配件
没有特定配件。
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using the tweezers, gently pull the ribbon wiring near where it connects to the motherboard to disconnect the ribbon wiring and the display screen from the motherboard.
Remove the screen from the device.
另外一个人完成了本指南。
2条评论
I got the ribbon off. There is a plastic piece that flops around that the ribbon was adhered to. Will the replacement ribbon have some type of adhesive on it for installation? Thanks.
