简介
If your device is not turning on you may need to replace a dead or faulty battery. Use this guide to replace the battery in your Garmin NUVI 2589 by completing the following replacement guide.
你所需要的
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
3等其他人完成本指南。
3条评论
Where can I buy this battery
Stan Levin
stan levin - 回复
where can I buy this battery
stan levin - 回复
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
