简介
If your device is not turning on you may need to replace a dead or faulty battery. Use this guide to replace the battery in your Garmin NUVI 2589 by completing the following replacement guide.
你所需要的
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
在这个步骤中使用的工具:Tweezers$3.99
Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
3等其他人完成本指南。
3条评论
Where can I buy this battery
Stan Levin
stan levin - 回复
where can I buy this battery
stan levin - 回复
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
