跳转到主内容
Garmin Nuvi 255W Speaker Replacement
你所需要的
  1. Garmin Nuvi 255W Speaker Replacement, Power Button: 步骤 1 中的图像 1,1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Speaker Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 255W Speaker Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Speaker Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 255W Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the power button.
  5. Garmin Nuvi 255W Speaker Replacement, Battery: 步骤 5 中的图像 1,1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Speaker Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 255W Speaker Replacement: 步骤 6 中的图像 2,2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Speaker Replacement: 步骤 7 中的图像 1,2 Garmin Nuvi 255W Speaker Replacement: 步骤 7 中的图像 2,2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
  8. Garmin Nuvi 255W Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    • Carefully disconnect the speaker from the motherboard. Slowly wiggling the connection makes it easier to disconnect.
  9. Garmin Nuvi 255W Speaker Replacement: 步骤 9 中的图像 1,2 Garmin Nuvi 255W Speaker Replacement: 步骤 9 中的图像 2,2
    • Using a plastic opening tool, wedge the speaker away from the device. The speaker is glued to the case so use force and leverage.
结论
Timothy
于01/26/12注册
73 声望
创作了3篇指南
团队
Cal Poly, Team 9-3, Regan Winter 2012 Cal Poly, Team 9-3, Regan Winter 2012 的会员
CPSU-REGAN-W12S9G3
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 3,958
