跳转到主内容
Garmin Nuvi 255W Battery Replacement
你所需要的
  1. Garmin Nuvi 255W Battery Replacement, Power Button: 步骤 1 中的图像 1,1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Battery Replacement: 步骤 2 中的图像 1,1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Battery Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 255W Battery Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Battery Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 255W Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the power button.
  5. Garmin Nuvi 255W Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Battery Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 255W Battery Replacement: 步骤 6 中的图像 2,2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Battery Replacement: 步骤 7 中的图像 1,2 Garmin Nuvi 255W Battery Replacement: 步骤 7 中的图像 2,2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
结论
15等其他人完成本指南。
Timothy
于01/26/12注册
73 声望
创作了3篇指南
团队
Cal Poly, Team 9-3, Regan Winter 2012 Cal Poly, Team 9-3, Regan Winter 2012 的会员
CPSU-REGAN-W12S9G3
5 名成员
创作了4篇指南
9条评论
Thanks for this very nicely illustrated guide.
RBStorms - 回复
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
rbol - 回复
Used these instructions to replace battery in my 5-year old Garmin nuvi 205W (which has the same access and internal geometry).
JRedmond - 回复
Thanks, great demonstration.
peter2x4 - 回复
This is great! I have run into a big problem, though. One of the screws is "unthreaded." The head has become smooth, and I can't unscrew it to get the cover off. Is there any way to get it off???
nancyw - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 70
总计 26,799
