跳转到主内容
Garmin Nuvi 2557LMT Screen Replacement
你所需要的
  1. Garmin Nuvi 2557LMT Screen Replacement, Garmin Nuvi 2557LMT Disassembly: 步骤 1 中的图像 1,1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Screen Replacement: 步骤 2 中的图像 1,1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Screen Replacement: 步骤 3 中的图像 1,1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Screen Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 2557LMT Screen Replacement: 步骤 4 中的图像 2,2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • With the screen facing down, firmly grip the sides of the screen frame and pop the screen out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 457
