跳转到主内容
Garmin Nuvi 2455LMT Back Panel Assembly Replacement
你所需要的
  1. Garmin Nuvi 2455LMT Back Panel Assembly Replacement, Back Panel Assembly: 步骤 1 中的图像 1,1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 步骤 3 中的图像 3,3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 956
