跳转到主内容
Garmin Nuvi 200w Screen Replacement
你所需要的
  1. Garmin Nuvi 200w Screen Replacement, Rear Cover: 步骤 1 中的图像 1,3 Garmin Nuvi 200w Screen Replacement, Rear Cover: 步骤 1 中的图像 2,3 Garmin Nuvi 200w Screen Replacement, Rear Cover: 步骤 1 中的图像 3,3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Screen Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 200w Screen Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 200w Screen Replacement: 步骤 3 中的图像 3,3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Screen Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 200w Screen Replacement: 步骤 4 中的图像 2,2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Screen Replacement, Display Assembly: 步骤 5 中的图像 1,3 Garmin Nuvi 200w Screen Replacement, Display Assembly: 步骤 5 中的图像 2,3 Garmin Nuvi 200w Screen Replacement, Display Assembly: 步骤 5 中的图像 3,3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Screen Replacement, Screen: 步骤 6 中的图像 1,3 Garmin Nuvi 200w Screen Replacement, Screen: 步骤 6 中的图像 2,3 Garmin Nuvi 200w Screen Replacement, Screen: 步骤 6 中的图像 3,3
    • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
    • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
    • Carefully separate the screen from the front cover.
结论
Matthew Eires
于03/08/17注册
319 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 365
