跳转到主内容
Garmin Nuvi 200w Display Assembly Replacement
你所需要的
  1. Garmin Nuvi 200w Display Assembly Replacement, Rear Cover: 步骤 1 中的图像 1,3 Garmin Nuvi 200w Display Assembly Replacement, Rear Cover: 步骤 1 中的图像 2,3 Garmin Nuvi 200w Display Assembly Replacement, Rear Cover: 步骤 1 中的图像 3,3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Display Assembly Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 200w Display Assembly Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 200w Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Display Assembly Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 200w Display Assembly Replacement: 步骤 4 中的图像 2,2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 1,3 Garmin Nuvi 200w Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 2,3 Garmin Nuvi 200w Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 3,3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
结论
另外一个人完成了本指南。
Clayton Golz
于03/08/17注册
128 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 401
