跳转到主内容
Garmin Nuvi 200W Rear Cover Replacement
你所需要的
  1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 1,3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 2,3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 3,3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200W  Rear Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200W  Rear Cover Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 200W  Rear Cover Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 200W  Rear Cover Replacement: 步骤 3 中的图像 3,3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200W  Rear Cover Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 200W  Rear Cover Replacement: 步骤 4 中的图像 2,2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
结论
Matthew Eires
于03/08/17注册
319 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 271
