跳转到主内容
Garmin Nuvi 200 Speaker Replacement
你所需要的
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: 步骤 1 中的图像 1,2 Garmin Nuvi 200 Speaker Replacement, Rear Casing: 步骤 1 中的图像 2,2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 200 Speaker Replacement: 步骤 3 中的图像 2,2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
  5. Garmin Nuvi 200 Speaker Replacement: 步骤 5 中的图像 1,1
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: 步骤 6 中的图像 1,3 Garmin Nuvi 200 Speaker Replacement: 步骤 6 中的图像 2,3 Garmin Nuvi 200 Speaker Replacement: 步骤 6 中的图像 3,3
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
结论
3等其他人完成本指南。
Anjelica
于04/11/10注册
564 声望
创作了3篇指南
团队
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G90
4 名成员
创作了9篇指南
2条评论
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - 回复
Where can you buy replacement speakers for the Garmin units?
Brat Fry - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 14
总计 6,983
