跳转到主内容
Garmin Nuvi 200 Display Replacement
你所需要的
  1. Garmin Nuvi 200 Display Replacement, Rear Casing: 步骤 1 中的图像 1,2 Garmin Nuvi 200 Display Replacement, Rear Casing: 步骤 1 中的图像 2,2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Display Replacement: 步骤 2 中的图像 1,1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Display Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 200 Display Replacement: 步骤 3 中的图像 2,2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Display Replacement, Display: 步骤 4 中的图像 1,1
    • Apply pressure to the tabs holding the screen in place with the plastic opening tool
  5. Garmin Nuvi 200 Display Replacement: 步骤 5 中的图像 1,2 Garmin Nuvi 200 Display Replacement: 步骤 5 中的图像 2,2
    • Apply pressure to the same tabs again to remove the front of the screen.
  6. Garmin Nuvi 200 Display Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 200 Display Replacement: 步骤 6 中的图像 2,2
    • Peel away the material holding the ribbon cable in place.
    • Peeling the sticker halfway will allow you to access the ribbon cable. Removing it fully will allow you to detach the upper case from the lower case.
  7. Garmin Nuvi 200 Display Replacement: 步骤 7 中的图像 1,2 Garmin Nuvi 200 Display Replacement: 步骤 7 中的图像 2,2
    • Disconnect the ribbon cable from the logic board.
    • Make sure to disconnect the cable from both ports.
  8. Garmin Nuvi 200 Display Replacement: 步骤 8 中的图像 1,2 Garmin Nuvi 200 Display Replacement: 步骤 8 中的图像 2,2
    • The display consists of two screens which are held together by the ribbon.
结论
4等其他人完成本指南。
Nick
于04/11/10注册
7 声望
撰写一个指南
团队
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G90
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 10,896
