跳转到主内容
Garmin Nuvi 1490T Display Screen Replacement
你所需要的
  1. Garmin Nuvi 1490T Display Screen Replacement, Front Frame Panel: 步骤 1 中的图像 1,1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Display Screen Replacement: 步骤 2 中的图像 1,1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Display Screen Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 1490T Display Screen Replacement: 步骤 3 中的图像 2,2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: 步骤 4 中的图像 1,3 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: 步骤 4 中的图像 2,3 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: 步骤 4 中的图像 3,3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Display Screen Replacement: 步骤 5 中的图像 1,3 Garmin Nuvi 1490T Display Screen Replacement: 步骤 5 中的图像 2,3 Garmin Nuvi 1490T Display Screen Replacement: 步骤 5 中的图像 3,3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Display Screen Replacement, Display Screen: 步骤 6 中的图像 1,3 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: 步骤 6 中的图像 2,3 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: 步骤 6 中的图像 3,3
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
  7. Garmin Nuvi 1490T Display Screen Replacement: 步骤 7 中的图像 1,2 Garmin Nuvi 1490T Display Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
  8. Garmin Nuvi 1490T Display Screen Replacement: 步骤 8 中的图像 1,3 Garmin Nuvi 1490T Display Screen Replacement: 步骤 8 中的图像 2,3 Garmin Nuvi 1490T Display Screen Replacement: 步骤 8 中的图像 3,3
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
结论
5等其他人完成本指南。
Ricardo Solis
于01/20/16注册
1,037 声望
创作了6篇指南
团队
USF Tampa, Team 15-2, Remmell Spring 2016 USF Tampa, Team 15-2, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G2
4 名成员
创作了6篇指南
一条评论
Awesome!! Thank you for putting this out there. Helped me save buying a new gps when the screen on my got damaged.
George Gearing - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,640
