跳转到主内容
Garmin Nuvi 1490T Battery Replacement
你所需要的
  1. Garmin Nuvi 1490T Battery Replacement, Front Frame Panel: 步骤 1 中的图像 1,1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Battery Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 1490T Battery Replacement: 步骤 3 中的图像 2,2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Battery Replacement, Second Frame Panel: 步骤 4 中的图像 1,3 Garmin Nuvi 1490T Battery Replacement, Second Frame Panel: 步骤 4 中的图像 2,3 Garmin Nuvi 1490T Battery Replacement, Second Frame Panel: 步骤 4 中的图像 3,3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Battery Replacement: 步骤 5 中的图像 1,3 Garmin Nuvi 1490T Battery Replacement: 步骤 5 中的图像 2,3 Garmin Nuvi 1490T Battery Replacement: 步骤 5 中的图像 3,3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Battery Replacement, Display Screen: 步骤 6 中的图像 1,3 Garmin Nuvi 1490T Battery Replacement, Display Screen: 步骤 6 中的图像 2,3 Garmin Nuvi 1490T Battery Replacement, Display Screen: 步骤 6 中的图像 3,3
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
  7. Garmin Nuvi 1490T Battery Replacement: 步骤 7 中的图像 1,2 Garmin Nuvi 1490T Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
  8. Garmin Nuvi 1490T Battery Replacement: 步骤 8 中的图像 1,3 Garmin Nuvi 1490T Battery Replacement: 步骤 8 中的图像 2,3 Garmin Nuvi 1490T Battery Replacement: 步骤 8 中的图像 3,3
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
  9. Garmin Nuvi 1490T Battery Replacement, Battery: 步骤 9 中的图像 1,3 Garmin Nuvi 1490T Battery Replacement, Battery: 步骤 9 中的图像 2,3 Garmin Nuvi 1490T Battery Replacement, Battery: 步骤 9 中的图像 3,3
    • Using the T5 Torx screw driver, remove the two 5.0 mm screws.
    • Using your hands, lift up the motherboard and fold it over.
  10. Garmin Nuvi 1490T Battery Replacement: 步骤 10 中的图像 1,3 Garmin Nuvi 1490T Battery Replacement: 步骤 10 中的图像 2,3 Garmin Nuvi 1490T Battery Replacement: 步骤 10 中的图像 3,3
    • Fold motherboard out of the way to reveal the white plastic end of the battery plug.
    • Using the tweezers, pull the white plastic connector to disconnect the battery from the motherboard.
    • Let the cord hang unattached.
  11. Garmin Nuvi 1490T Battery Replacement: 步骤 11 中的图像 1,2 Garmin Nuvi 1490T Battery Replacement: 步骤 11 中的图像 2,2
    • Return motherboard back to original position by flipping it back over.
    • Using the nylon spudger, dislodge the battery out of its socket.
    • Use a tool that is ESD-safe such as a nylon spudger or a plastic prying tool. Never use a metal spudger to take out the battery.
结论
7等其他人完成本指南。
Ricardo Solis
于01/20/16注册
1,037 声望
创作了6篇指南
团队
USF Tampa, Team 15-2, Remmell Spring 2016 USF Tampa, Team 15-2, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G2
4 名成员
创作了6篇指南
2条评论
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1490T Battery 361-00019-16
Mike - 回复
Thanks for the great instructions! Had I not given up on Garmin's video instruction I'm sure I would have destroyed my GPS. You saved the day for me. Again, THANKS!
Mike Billmaier - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 5,807
