跳转到主内容
Garmin Nuvi 1390LMT Battery Replacement
你所需要的
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 1390LMT Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: 步骤 3 中的图像 1,1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 1390LMT Battery Replacement: 步骤 4 中的图像 2,2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 1390LMT Battery Replacement: 步骤 6 中的图像 2,2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: 步骤 7 中的图像 1,1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: 步骤 8 中的图像 1,2 Garmin Nuvi 1390LMT Battery Replacement: 步骤 8 中的图像 2,2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
终点
3等其他人完成本指南。
Trey Ulsh
于10/22/15注册
537 声望
创作了3篇指南
团队
Montana Tech, Team 10-4, Shirk Fall 2015 Montana Tech, Team 10-4, Shirk Fall 2015 的会员
MTUM-SHIRK-F15S10G4
5 名成员
创作了3篇指南
一条评论
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 3,770
