跳转到主内容
Garmin Nüvi 52LM Disassembly
你所需要的
  1. Garmin Nüvi 52LM Disassembly, Garmin Nüvi 52LM Disassembly: 步骤 1 中的图像 1,2 Garmin Nüvi 52LM Disassembly, Garmin Nüvi 52LM Disassembly: 步骤 1 中的图像 2,2
    • Place the device face-down, with the screen facing the surface. There are 8.7mm screws located in each of the back 4 corners of the device. Using a T5 Torx screw bit, unscrew all four screws and leave them aside.
  2. Garmin Nüvi 52LM Disassembly: 步骤 2 中的图像 1,2 Garmin Nüvi 52LM Disassembly: 步骤 2 中的图像 2,2
    • Place a plastic opening tool in the seam between the back and front plates of the device. Using constant pressure, slowly and continuously slide the tool along the seam. The tool should disable each of the hooks holding the two plates together. If unsuccessful, apply slightly more pressure and try again.
    • Once all hooks are disabled, slowly separate the two plates, being careful not to damage the ribbon wire still connecting the two.
结论
Diya Jamwal
于01/24/17注册
101 声望
撰写一个指南
团队
Cal Poly, Team 10-1, Banghart Winter 2017 Cal Poly, Team 10-1, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 435
