跳转到主内容
加入维修社区 - 创建账户
Garmin GPSmap 60CSx Screen Replacement
你所需要的
    1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: 步骤 1 中的图像 1,1
      • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
      询问修复机器人
      添加评论
    2. Garmin GPSmap 60CSx Screen Replacement: 步骤 2 中的图像 1,1
      • Lift battery release up to remove battery cover.
      询问修复机器人
      添加评论
    3. Garmin GPSmap 60CSx Screen Replacement: 步骤 3 中的图像 1,2 Garmin GPSmap 60CSx Screen Replacement: 步骤 3 中的图像 2,2
      • Pull AA batteries out.
      询问修复机器人
      添加评论
    1. Garmin GPSmap 60CSx Screen Replacement, Screen: 步骤 4 中的图像 1,2 Garmin GPSmap 60CSx Screen Replacement, Screen: 步骤 4 中的图像 2,2
      • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
      • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
      • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
      询问修复机器人
      添加评论
    2. Garmin GPSmap 60CSx Screen Replacement: 步骤 5 中的图像 1,1
      • Take the spudger and place it in the bottom right corner of the black PCB cover.
      • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
      • It is best to do remove the bottom corners first.
      • Pull the PCB cover out of the GPSMap 60CSx.
      询问修复机器人
      添加评论
    3. Garmin GPSmap 60CSx Screen Replacement: 步骤 6 中的图像 1,2 Garmin GPSmap 60CSx Screen Replacement: 步骤 6 中的图像 2,2
      • Carefully use the spudger to lift the PCB a few centimeters.
      • Pull the PCB towards the bottom of the GPSMap 60CSx.
      • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
      询问修复机器人
      添加评论
    4. Garmin GPSmap 60CSx Screen Replacement: 步骤 7 中的图像 1,3 Garmin GPSmap 60CSx Screen Replacement: 步骤 7 中的图像 2,3 Garmin GPSmap 60CSx Screen Replacement: 步骤 7 中的图像 3,3
      • Apply light pressure to the four white tabs that are holding the screen in place.
      • The screen will now come off the PCB.
      询问修复机器人
      添加评论
    5. Garmin GPSmap 60CSx Screen Replacement: 步骤 8 中的图像 1,1
      • Turn the PCB over so the screen connector is facing you.
      • Move the screen out of the way for access to the screen connector.
      询问修复机器人
      添加评论
    6. Garmin GPSmap 60CSx Screen Replacement: 步骤 9 中的图像 1,3 Garmin GPSmap 60CSx Screen Replacement: 步骤 9 中的图像 2,3 Garmin GPSmap 60CSx Screen Replacement: 步骤 9 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to pull the two white pins on the connector forward.
      询问修复机器人
      添加评论
    7. Garmin GPSmap 60CSx Screen Replacement: 步骤 10 中的图像 1,1
      • Remove the screen ribbon connector and screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
2指南评论
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - 回复 分享
Thank you for these step by step detailed instructions.
jlciscorp - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 49
总计 5,754
