跳转到主内容
Garmin GPSmap 60CSx Keypad Buttons Replacement
你所需要的
  1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Back Cover and AA Batteries: 步骤 1 中的图像 1,1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 2 中的图像 1,1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 3 中的图像 1,2 Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 3 中的图像 2,2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: 步骤 4 中的图像 1,2 Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: 步骤 4 中的图像 2,2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 5 中的图像 1,1
    • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
    • The previous step will need to be done to the other three corners.
    • It is best to do the two bottom corners first.
    • Pull the black PCB board out of the GPSMap 60 CSx.
  6. Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 6 中的图像 1,2 Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 6 中的图像 2,2
    • Carefully use a spudger to lift the PCB a few centimeters.
    • Pull the PCB out towards the bottom of the GPSMap 60CSx.
    • This will pull out all the main components including the antenna and the screen.
  7. Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 7 中的图像 1,2 Garmin GPSmap 60CSx Keypad Buttons Replacement: 步骤 7 中的图像 2,2
    • Take the front panel and apply light force to the buttons.
    • The buttons are part of one unit and should all pop out at once.
结论
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 3,051
