跳转到主内容
Garmin GPSmap 60CSx Battery Terminal Replacement
你所需要的
  1. Garmin GPSmap 60CSx Battery Terminal Replacement, Back Cover and AA Batteries: 步骤 1 中的图像 1,1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 2 中的图像 1,1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 3 中的图像 1,2 Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 3 中的图像 2,2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Battery Terminal Replacement, Battery Terminals: 步骤 4 中的图像 1,1
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
  5. Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 5 中的图像 1,2 Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 5 中的图像 2,2
    • Place spudger behind the lower right battery terminal.
    • Push spudger behind the battery terminal to pop it out of place.
    • Now do the same on the bottom left side.
  6. Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 6 中的图像 1,2 Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 6 中的图像 2,2
    • Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
  7. Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 7 中的图像 1,2 Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 7 中的图像 2,2
    • Flip the back panel over to expose the backs of the top battery terminals.
    • Use a metal spudger to remove the glue that covers them.
  8. Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 8 中的图像 1,2 Garmin GPSmap 60CSx Battery Terminal Replacement: 步骤 8 中的图像 2,2
    • Flip the back panel back over to view the battery compartment.
    • Place the spudger behind one of the top remaining battery terminals.
    • Push the spudger down and pop the battery terminal out of place.
    • Repeat with the remaining battery terminal.
结论
另外一个人完成了本指南。
10指南评论
What did you use to replace the contacts?
Austin Chopra - 回复
Where can I buy replacement terminals?
Mitch - 回复
Mitch, Garmin just told me they do no sell replacement terminals for this 60CSx. Were you able to find any?
Ernie Sammons -
Where can I find replacement battery terminals for a
Garmin 60CS4?
Sonny Pierce - 回复
Where can I find replacement battery terminals for a Garmin Map76CS?
Paul - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 143
总计 11,301
