当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Orient the GPS V backside up.
With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
With the spudger, gently pry the back plate off the unit starting at the corners.
Open the back plate about 35°, use the antenna side act like a hinge.
Do NOT remove the back plate all the way, there are cables connected to it.
Locate the white 8-pin connector on the logic board and disconnect it.
Open the device all the way, making sure to not disconnect the brown antenna wire.
With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
You may need to rotate the device to get better access to the screw.
Locate the ribbon connector on the logic board.
With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
With the spudger, gently work the ribbon cable out of the connector until it is free.
With the spudger, gently pry out the logic board.
Be careful to not disconnect the brown antenna wire as you remove the logic board.
Locate the brown wire connection on the logic board.
Carefully apply heat with the soldering iron while gently pulling on the brown wire.
It may take some time to heat the flux up before the wire can be pulled out.
Pull brown wire free of the logic board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
