跳转到主内容
加入维修社区 - 创建账户
Garmin GPS V Logic Board Replacement
你所需要的
  1. Garmin GPS V Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,3 Garmin GPS V Logic Board Replacement, Logic Board: 步骤 1 中的图像 2,3 Garmin GPS V Logic Board Replacement, Logic Board: 步骤 1 中的图像 3,3
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
    询问修复机器人
  2. Garmin GPS V Logic Board Replacement: 步骤 2 中的图像 1,2 Garmin GPS V Logic Board Replacement: 步骤 2 中的图像 2,2
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
    询问修复机器人
  3. Garmin GPS V Logic Board Replacement: 步骤 3 中的图像 1,2 Garmin GPS V Logic Board Replacement: 步骤 3 中的图像 2,2
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
    询问修复机器人
  4. Garmin GPS V Logic Board Replacement: 步骤 4 中的图像 1,2 Garmin GPS V Logic Board Replacement: 步骤 4 中的图像 2,2
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
    询问修复机器人
  5. Garmin GPS V Logic Board Replacement: 步骤 5 中的图像 1,3 Garmin GPS V Logic Board Replacement: 步骤 5 中的图像 2,3 Garmin GPS V Logic Board Replacement: 步骤 5 中的图像 3,3
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
    询问修复机器人
  6. Garmin GPS V Logic Board Replacement: 步骤 6 中的图像 1,2 Garmin GPS V Logic Board Replacement: 步骤 6 中的图像 2,2
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
    询问修复机器人
  7. Garmin GPS V Logic Board Replacement: 步骤 7 中的图像 1,1
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
    询问修复机器人
结论
2等其他人完成本指南。
Connor
于01/23/12注册
194 声望
创作了4篇指南
团队
Cal Poly, Team 3-25, Amido Winter 2012 Cal Poly, Team 3-25, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G25
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 76
总计 5,954
