跳转到主内容
Garmin Forerunner 25 Motherboard Replacement
你所需要的
  1. Garmin Forerunner 25 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
结论
Dustin Persohn
于03/21/18注册
208 声望
创作了2篇指南
团队
IUPUI, Team S5-G3, Baechle Spring 2018 IUPUI, Team S5-G3, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 638
