跳转到主内容
Garmin Forerunner 25 Battery Replacement
你所需要的
  1. Garmin Forerunner 25 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: 步骤 2 中的图像 1,1
    • Pry the old battery out using a plastic spudger.
结论
另外一个人完成了本指南。
Dustin Persohn
于03/21/18注册
208 声望
创作了2篇指南
团队
IUPUI, Team S5-G3, Baechle Spring 2018 IUPUI, Team S5-G3, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G3
3 名成员
创作了3篇指南
11条评论
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - 回复
I need to know as well. What kind of battery is it? PD…????
girlie_360 - 回复
Just look at the last picture. PD2430C1
Leandro Lind - 回复
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - 回复
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 27
过去 30 天: 130
总计 5,034
