简介
Battery replacement is a common fix for devices as they age. This fix is quick and easy with the use of a T5 screwdriver.
你所需要的
Place the watch on a hard surface with the screen facing down.
Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
另外一个人完成了本指南。
11条评论
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
I need to know as well. What kind of battery is it? PD…????
girlie_360 - 回复
Just look at the last picture. PD2430C1
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
