跳转到主内容
Garmin Fenix 3 Wrist Strap Replacement
你所需要的
  1. Garmin Fenix 3 Wrist Strap Replacement, Wrist Strap: 步骤 1 中的图像 1,1
    • Identify the screws near the bases of two wrist straps.
  2. Garmin Fenix 3 Wrist Strap Replacement: 步骤 2 中的图像 1,1
    • Hold one screwdriver firmly in one hand, as demonstrated in the image.
  3. Garmin Fenix 3 Wrist Strap Replacement: 步骤 3 中的图像 1,1
    • Secure the watch in the same hand, positioning the screwdriver over the screw.
  4. Garmin Fenix 3 Wrist Strap Replacement: 步骤 4 中的图像 1,1
    • Once the watch is secure, insert the screwdriver into the screw, and hold firmly.
  5. Garmin Fenix 3 Wrist Strap Replacement: 步骤 5 中的图像 1,1
    • With the watch and the first screwdriver secure, insert the second screwdriver into the opposite screw.
    • Holding the first screwdriver firmly, unscrew using the second screwdriver.
  6. Garmin Fenix 3 Wrist Strap Replacement: 步骤 6 中的图像 1,1
    • Remove the bar from the wrist strap to release.
    • Depending on which side the bar is inserted, you may end up loosening the screw instead of the bar. Keep this in mind to avoid losing your screws.
  7. Garmin Fenix 3 Wrist Strap Replacement: 步骤 7 中的图像 1,1
    • Repeat this process for the other side, adjusting the position of the watch accordingly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 3,667
