跳转到主内容
Garmin Fenix 3 Motherboard Replacement
你所需要的
  1. Garmin Fenix 3 Motherboard Replacement, Display Assembly: 步骤 1 中的图像 1,2 Garmin Fenix 3 Motherboard Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Set the watch face aside.
  5. Garmin Fenix 3 Motherboard Replacement, GPS Antenna: 步骤 5 中的图像 1,1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the antenna, and set it aside.
  7. Garmin Fenix 3 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 Garmin Fenix 3 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 Garmin Fenix 3 Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Locate the two silver 1.4 mm T5 screws, and carefully unscrew them.
    • To avoid losing or dropping the screws once they are loose, use tweezers to extract them.
  8. Garmin Fenix 3 Motherboard Replacement: 步骤 8 中的图像 1,2 Garmin Fenix 3 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift the watch and turn it over one hand. The motherboard should fall out easily.
    • When reinserting your motherboard, slide it in instead of pressing it. The motherboard must go beneath a lip at the base of the watch body.
  9. Garmin Fenix 3 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Using the spudger, separate the motherboard from the battery, which are both held together with a mild adhesive.
  10. Garmin Fenix 3 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Motherboard without metal cover
结论
6等其他人完成本指南。
18指南评论
Hello,
i’m looking for replacement of start/stop button micro switch. Do you know what is the switch number which i can look for?
Thank you
Jan Stefan - 回复
that's my problem too and i can't find any solution.
Hamidmonti -
How did you remove the metal cover from the moterboard (last picture)
slowrun - 回复
Where can I find a replacement Motherboard ? None of my buttons are responding and I can’t even do a Factory reset.
All that works is switching off and back on.
arnaud.lhote - 回复
I have exact same issue. I sent my watch to official repair service to Split (Croatia) and they said they aren’t able to fix it. I can see only main screen of the watch, buttons don’t respond at all. Would like to know how to fix the issue.
ilija.veselica -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 103
总计 10,870
