跳转到主内容
Garmin Fenix 3 HR Motherboard Replacement
你所需要的
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: 步骤 2 中的图像 1,2 Garmin Fenix 3 HR Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: 步骤 4 中的图像 1,2 Garmin Fenix 3 HR Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: 步骤 5 中的图像 1,1
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: 步骤 7 中的图像 1,1
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: 步骤 8 中的图像 1,1
    • Now attach battery to new motherboard and reassemble.
    Where can i get a new motherboard
    merlion chan - 回复
结论
5等其他人完成本指南。
Jacob Smiley
于03/26/18注册
277 声望
撰写一个指南
团队
IUPUI, Team S1-G6, Harley Spring 2018 IUPUI, Team S1-G6, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G6
3 名成员
创作了4篇指南
2条评论
And where would one source replacement motherboard?
jonathan.hatchuel - 回复
donde puedo encontras placa.madre reeemplazo????
luis zavala - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 4,753
