跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will give you step-by-step instructions on how to quickly swap out that old battery for a new one.
  1. Remove the five 7mm screws with H1.3 hex screwdriver. Remove the five 7mm screws with H1.3 hex screwdriver.
    • Remove the five 7mm screws with H1.3 hex screwdriver.
    Why is a H1.3 being used here when the screws look like TORX?
    Stuart Kerr - 回复
    They are in fact TORX bits. A T5 driver fit neatly.
    Matthew Cole - 回复
  2. Use a plastic opening tool to remove the face of the device to expose the inner components. There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well. Be careful with the ribbon that connects the motherboard to the display.
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
    Is there a trick to attaching Ribon back on?
    brad - 回复
  3. Proceed to disconnect the ribbon from the motherboard using tweezers.
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
    The ribbon connection end just needs to be used pulled up. No need of force.
    Asif Shafiq - 回复
    Trick to reattaching?
    brad - 回复
    You do not need to disconnect the motherboard for this, and it is challenging to reconnect without risking damage. Recommend leave it attached and move onto next step
    Mark - 回复
  4. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  5. Using a T5 screwdriver, remove the two 5mm screws. The motherboard should now move freely.
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
    I needed a T4 for these screws
    Simon Chis - 回复
  6. Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
    Fenix 3 does not have this ribbon.
    Asif Shafiq - 回复
  7. Disconnect wires connecting battery to motherboard.
    • Disconnect wires connecting battery to motherboard.
    The battery connector just needs to be used pulled up. No need of force.
    Asif Shafiq - 回复
    Yes, not pulled backwards, just straight up. I wish I had seen this comment before hand. Maybe Victor could add it to the notes? Otherwise a great guide.
    Mark Grant - 回复
    Battery PN = FLPB342735-P1 - Li Ion 3,7V - 290 mAh
    Jose Gustavo Abreu Murta - 回复
  8. The battery is glued to the motherboard and will need pried off using the nylon spudger.
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  9. Now attach the new battery with adhesive and reassemble.
    • Now attach the new battery with adhesive and reassemble.
    Where is everyone getting batteries from? I purchased one off Amazon and it only lasted two hours after charging overnight. Thank you
    jerry quintana - 回复
    The battery connector PRESSES in from the top. It does not slide in.
    Gale Otterholt - 回复
结论
17等其他人完成本指南。
Victor Tanguy
于2018年03月26日注册
696 信誉积分
撰写一个指南
团队
IUPUI, Team S1-G6, Harley Spring 2018 IUPUI, Team S1-G6, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G6
3 名成员
创作了2篇指南
Does anybody do It in a fenix 5?
Fernando Alcaraz - 回复
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - 回复
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
Howdy,
Followed all your steps but now the new battery will not charge. Could I have missed something in replacing the battery somehow? Pins not making contact or so?
Adrian - 回复
I had a similar issue, I think you need to make sure the screws on the battery board are firmly tightened. Seems odd but worked for me
adagnall -
I’ve just followed these steps, and with £4.50 for a precision torx set, and £14.50 for a battery that came the next day by UPS, it’s saved me loads. The couple of things I would add are - you can use double sided tape to attached the new battery, and buy a battery with the connector already attached unless you are an electrician it saves the fuss, and make sure the connector is fully in place, it’s easy for it to be marginally out and you’ll get no power.
thanks!
Jason Clarke - 回复
Can you please post a link to a suitable battery? especially that one with the “already attached solution” seems very interessting to me :) Thank you!
Marcus - 回复
Here's the replacement battery needed for the Fenix 3 HR. It's brand new, it comes with all the necessary installation tools and it has a 1 year warranty! Fenix 3 HR Replacement Battery
Mike -
Do you think there’s room to put a larger MaH battery in there?
Brian Vinci - 回复
Thank you very much. Clear and easy to follow. I would only add there how to detach the battery. Not to pull but pull up from the motherboard.
Thanks
Stanislav Vincent - 回复
What about the seal after replacement ? Is it preserved so water does not pernetrate ?
Milen Genchev - 回复
Has anyone had issues with the waterproofing after this repair?
LikeARabbit - 回复
Thank you for the guide as it is very helpful! Here's the replacement battery needed for the Fenix 3 HR. It's brand new, it comes with all the necessary installation tools and it has a 1 year warranty! Fenix 3 HR Replacement Battery
Mike - 回复
Hi,
thank you, that helps a lot!
Are there no new seals necessary and is the Garmin still waterproof?
Thanks!
Tom
thomas - 回复
In my fenix 5 the battery connector is welded to the socket. Impossible to extract.
Alessandro Rossi - 回复
添加评论
浏览统计数据:
过去的24小时: 36
过去的7天: 290
过去的30天: 1,088
总计 19,728
