跳转到主内容
Garmin Fenix 3 HR Battery Replacement
你所需要的
  1. Garmin Fenix 3 HR Battery Replacement, Battery: 步骤 1 中的图像 1,2 Garmin Fenix 3 HR Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: 步骤 2 中的图像 1,3 Garmin Fenix 3 HR Battery Replacement: 步骤 2 中的图像 2,3 Garmin Fenix 3 HR Battery Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: 步骤 3 中的图像 1,1
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: 步骤 4 中的图像 1,2 Garmin Fenix 3 HR Battery Replacement: 步骤 4 中的图像 2,2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: 步骤 5 中的图像 1,1
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: 步骤 6 中的图像 1,1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: 步骤 7 中的图像 1,1
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: 步骤 8 中的图像 1,1
    • Now attach the new battery with adhesive and reassemble.
结论
40等其他人完成本指南。
Victor Tanguy
于03/26/18注册
1,329 声望
撰写一个指南
团队
IUPUI, Team S1-G6, Harley Spring 2018 IUPUI, Team S1-G6, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G6
3 名成员
创作了4篇指南
29条评论
Does anybody do It in a fenix 5?
Fernando Alcaraz - 回复
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - 回复
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 100
过去 30 天: 474
总计 65,764
