跳转到主内容
Garmin Fenix 3 GPS Antenna Replacement
你所需要的
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: 步骤 1 中的图像 1,2 Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: 步骤 4 中的图像 1,1
    • Set the watch face aside.
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: 步骤 5 中的图像 1,1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the antenna, and set it aside.
结论
另外一个人完成了本指南。
8指南评论
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - 回复
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - 回复
Hi did you find gps antenna
Abdessamad Faroque - 回复
Could you please add a link where to buy the antenna?
marco475 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 75
总计 6,595
