跳转到主内容
Garmin Fenix 3 Display Assembly Replacement
你所需要的
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,2 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Set the watch face aside.
结论
6等其他人完成本指南。
4指南评论
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - 回复
I have the same question.
Nicolas Chartier -
How do you make sure ribbon connector is aligned correctly
Steven - 回复
I have Fennix3, replaced the battery with new one (tested the battery before fixing), however, after complete assembly the watch does not start up? any hints?
Abdullah - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 70
总计 10,381
