跳转到主内容
Garmin Fenix 2 Motherboard Replacement
你所需要的
  1. Garmin Fenix 2 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Garmin Fenix 2 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Garmin Fenix 2 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  2. Garmin Fenix 2 Motherboard Replacement: 步骤 2 中的图像 1,2 Garmin Fenix 2 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  3. Garmin Fenix 2 Motherboard Replacement: 步骤 3 中的图像 1,2 Garmin Fenix 2 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
  4. Garmin Fenix 2 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Use a spudger to pry open the power ribbon from the main board.
  5. Garmin Fenix 2 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
  6. Garmin Fenix 2 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the spudger to pry the motherboard out of the housing.
  7. Garmin Fenix 2 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Once removed simply separate the digitizer from the main board.
  8. Garmin Fenix 2 Motherboard Replacement: 步骤 8 中的图像 1,2 Garmin Fenix 2 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
结论
5等其他人完成本指南。
Brandon Barger
于02/13/16注册
1,219 声望
创作了5篇指南
团队
IUPUI, Team 54-4, Wilson Spring 2016 IUPUI, Team 54-4, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S54G4
3 名成员
创作了7篇指南
2指南评论
Ottima, le prime guide che trovo per Garmin Fenix 2. Io metterei una foto con le specifiche della batteria. Saluti.
Ciro Filomeno - 回复
Hi there, any idea where I can buy motherboard replacement for my Fenix 1?
hasmanizam - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 16
总计 4,797
