简介
We are going to remove the motherboard out of the Garmin Fenix 2 watch. You will need a Torx T9 screwdriver along with a nylon spudger for this fix.
你所需要的
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
5等其他人完成本指南。
2指南评论
Ottima, le prime guide che trovo per Garmin Fenix 2. Io metterei una foto con le specifiche della batteria. Saluti.
Hi there, any idea where I can buy motherboard replacement for my Fenix 1?
hasmanizam - 回复
