跳转到主内容
Garmin Fenix 2 Battery Replacement
你所需要的
  1. Garmin Fenix 2 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Garmin Fenix 2 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Garmin Fenix 2 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  2. Garmin Fenix 2 Battery Replacement: 步骤 2 中的图像 1,2 Garmin Fenix 2 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  3. Garmin Fenix 2 Battery Replacement: 步骤 3 中的图像 1,2 Garmin Fenix 2 Battery Replacement: 步骤 3 中的图像 2,2
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
结论
11等其他人完成本指南。
Brandon Barger
于02/13/16注册
1,219 声望
创作了5篇指南
团队
IUPUI, Team 54-4, Wilson Spring 2016 IUPUI, Team 54-4, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S54G4
3 名成员
创作了7篇指南
7指南评论
can you tell us exactly which battery should be used? Thanks in advance!
fabrizionannini - 回复
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
homanchris -
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
https://buy.garmin.com/en-US/US/into-spo...
L P -
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
L P - 回复
After some research on eBay the correct battery size should be PD3555 3.7V which is 500mAh.
Yang - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 185
总计 35,113
