跳转到主内容
加入维修社区 - 创建账户
Garmin Edge 830 Battery Replacement
你所需要的
  1. Garmin Edge 830 Battery Replacement, Touch Display: 步骤 1 中的图像 1,1
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
    添加评论
  2. Garmin Edge 830 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
    添加评论
  3. Garmin Edge 830 Battery Replacement: 步骤 3 中的图像 1,1
    • Use the iFixit plastic opening tool to pry open the screen.
    询问修复机器人
    添加评论
  4. Garmin Edge 830 Battery Replacement, Motherboard: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
    询问修复机器人
    添加评论
  5. Garmin Edge 830 Battery Replacement: 步骤 5 中的图像 1,1
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
    询问修复机器人
    添加评论
  6. Garmin Edge 830 Battery Replacement: 步骤 6 中的图像 1,1
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
    询问修复机器人
    添加评论
  7. Garmin Edge 830 Battery Replacement: 步骤 7 中的图像 1,2 Garmin Edge 830 Battery Replacement: 步骤 7 中的图像 2,2
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
    询问修复机器人
    添加评论
  8. Garmin Edge 830 Battery Replacement, Battery: 步骤 8 中的图像 1,1
    • Use the halberd spudger to lift and remove the battery from the back cover.
    添加评论
结论
取消:我没有完成这个指南。
4指南评论
I have a Garmin 820. I've seen a video by NewLife2OldStuff on YouTube and they don't heat the seal. But I've tried their method and cant get the opening tool in the groove.
Is the removal of the screen on the 830 the same for the 820? It looks similar.
Gary Roy Hogg - 回复 分享
ciao ... puoi indicare le spegifiche giuste della batteria per garmin edge 830?
hi...can you give the correct battery specifications for garmin edge 830?
grazie
giancarlodilorenzo@gmail.com
gianca - 回复 分享
I would like to replace the battery and therefore I am looking for a compatible model
gianca - 回复 分享
I do not recommend trying to change the battery. It's better to buy a case with a prepared battery and change the board and display. There are flat cables coming from the back charger and one of the microphone which are attached to a glue/paste. I destroyed the back charger cable, someone else the microphone cable as they were glued to the battery. There is no way to get any replacement for these cables as of May 2025.
The Jimmy tool and Ifix opener are also not good for opening the display. Better use a X-Acto or Craft knife. The display also easily cracks when trying to lift it out of the case. So keep some kind of weight at the display, especially the corners are sensitive. Cases with battery cost around 25, the display 20.
Ano Nymous - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 71
过去 30 天: 263
总计 12,985
