跳转到主内容
加入维修社区 - 创建账户
Garmin Edge 830 Back Cover Replacement
你所需要的
  1. Garmin Edge 830 Back Cover Replacement, Touch Display: 步骤 1 中的图像 1,1
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
  2. Garmin Edge 830 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
  3. Garmin Edge 830 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Back Cover Replacement, Motherboard: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Back Cover Replacement: 步骤 6 中的图像 1,1
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Back Cover Replacement: 步骤 7 中的图像 1,2 Garmin Edge 830 Back Cover Replacement: 步骤 7 中的图像 2,2
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
  8. Garmin Edge 830 Back Cover Replacement, Battery: 步骤 8 中的图像 1,1
    • Use the halberd spudger to lift and remove the battery from the back cover.
  9. Garmin Edge 830 Back Cover Replacement, Back Cover: 步骤 9 中的图像 1,1
    • Once all previous steps are completed, you will be left with the back cover.
结论
另外一个人完成了本指南。
Alden Gibbs
于03/21/22注册
265 声望
创作了3篇指南
1指南评论
What are the steps required to put the screen back on? What glue should we use and how?
Odhita Kamayana - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 59
总计 2,288
