跳转到主内容
Garmin Edge 530 LCD Screen Display Replacement
你所需要的
  1. Garmin Edge 530 LCD Screen Display Replacement, LCD Screen Display: 步骤 1 中的图像 1,1
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
  2. Garmin Edge 530 LCD Screen Display Replacement: 步骤 2 中的图像 1,3 Garmin Edge 530 LCD Screen Display Replacement: 步骤 2 中的图像 2,3 Garmin Edge 530 LCD Screen Display Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
  3. Garmin Edge 530 LCD Screen Display Replacement: 步骤 3 中的图像 1,3 Garmin Edge 530 LCD Screen Display Replacement: 步骤 3 中的图像 2,3 Garmin Edge 530 LCD Screen Display Replacement: 步骤 3 中的图像 3,3
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
  4. Garmin Edge 530 LCD Screen Display Replacement: 步骤 4 中的图像 1,1
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
结论
To reassemble your device, follow these instructions in reverse order to attach the new LCD screen.
6等其他人完成本指南。
Caroline Abbud
于02/22/22注册
217 声望
撰写一个指南
团队
Clemson, Team 2-1, Hunter Spring 2022 Clemson, Team 2-1, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G1
5 名成员
创作了17篇指南
6指南评论
Thanks for the instructions!
I didn't have a spudger, so I used a small knife instead.
For the assembly: when you put the new screen on the hardest part is the connection of the cable to the small socket of the back plate.
Also don't forget to put on some glue to the edges of the screen. In that way it stays better in place and is more water resistant.
Tim Sinke - 回复
worked well for me. Got screen off ebay from US seller. The glue was a little tough to get the old screen out. Ended up destroying it completely in the process, which was ok of course. Try to scrape as much of the old glue off as you can. New screen went in fine. Used a little glue to keep it in.
Jonathan Hair - 回复
Hi, I was able to replace my Garmin 530 LCD screen, but the new one that I installed has a poor backlight(?) and appears permanently dimmed and is diffiult to read. (All the settings are on highest screen brightness). The seller is non responsive to my complaint. Can anyone advise of where I can buy a decent after market LCD screen?
Rob J. - 回复
Appreciated the guide. The connector is very small, so it took a lot of tries to get it connected. No adhesive is mentioned but the adhesive that made the old screen such a bear to pry up seems to have grabbed the new one pretty securely. (I put it in place to test the new screen)
Carmen Thompson - 回复
Was able to get a screen from "Garmade" for $87 which has worked well, really pleased with the quality. This was my third screen after the one I got from Aliexpress was permanently dimmed and unusable.
Rob J. - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 86
过去 30 天: 378
总计 22,211
