跳转到主内容
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
你所需要的
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: 步骤 1 中的图像 1,2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: 步骤 2 中的图像 1,2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: 步骤 2 中的图像 2,2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: 步骤 3 中的图像 1,3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: 步骤 3 中的图像 2,3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: 步骤 3 中的图像 3,3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 1,540
