跳转到主内容
Garmin Drive 60LM Speaker Replacement
你所需要的
  1. Garmin Drive 60LM Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Garmin Drive 60LM Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Speaker Replacement: 步骤 2 中的图像 1,3 Garmin Drive 60LM Speaker Replacement: 步骤 2 中的图像 2,3 Garmin Drive 60LM Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the back panel using the metal spudger tool.
    • You will not be able to remove the back panel entirely. Make sure to separate the back panel slowly so that you do not rip the orange ribbon inside.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Speaker Replacement: 步骤 3 中的图像 1,3 Garmin Drive 60LM Speaker Replacement: 步骤 3 中的图像 2,3 Garmin Drive 60LM Speaker Replacement: 步骤 3 中的图像 3,3
    • Use a plastic spudger tool to lift the wires from behind the motherboard.
    • Carefully disconnect the wires attaching the speaker to the motherboard using your fingers.
  4. Garmin Drive 60LM Speaker Replacement: 步骤 4 中的图像 1,2 Garmin Drive 60LM Speaker Replacement: 步骤 4 中的图像 2,2
    • Using a plastic spudger and your fingers, remove the speaker from the device.
结论
另外一个人完成了本指南。
Andy Flores
于01/30/17注册
238 声望
创作了2篇指南
团队
Baylor, Team 3-3, Whitney Spring 2017 Baylor, Team 3-3, Whitney Spring 2017 的会员
BU-WHITNEY-S17S3G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 497
