跳转到主内容
Garmin Drive 60LM Motherboard Replacement
你所需要的
  1. Garmin Drive 60LM Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Garmin Drive 60LM Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Motherboard Replacement: 步骤 2 中的图像 1,3 Garmin Drive 60LM Motherboard Replacement: 步骤 2 中的图像 2,3 Garmin Drive 60LM Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Motherboard Replacement: 步骤 3 中的图像 1,3 Garmin Drive 60LM Motherboard Replacement: 步骤 3 中的图像 2,3 Garmin Drive 60LM Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  4. Garmin Drive 60LM Motherboard Replacement: 步骤 4 中的图像 1,2 Garmin Drive 60LM Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using the T4 Torx screwdriver, unscrew the four screws (1/2 cm, 5mm) from the motherboard.
    • Then, lift the motherboard out of its position.
  5. Garmin Drive 60LM Motherboard Replacement: 步骤 5 中的图像 1,2 Garmin Drive 60LM Motherboard Replacement: 步骤 5 中的图像 2,2
    • Flip the motherboard over towards the right.
    • Then, carefully disconnect the two sets of wires that are connected to the battery and the speaker using your fingers.
    • Remove the motherboard.
结论
Andy Flores
于01/30/17注册
238 声望
创作了2篇指南
团队
Baylor, Team 3-3, Whitney Spring 2017 Baylor, Team 3-3, Whitney Spring 2017 的会员
BU-WHITNEY-S17S3G3
4 名成员
创作了3篇指南
2条评论
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
th.lamouroux - 回复
i lost the screws while replacing the batterry. where do ifind the screws
Carolyn Mock - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 1,395
