跳转到主内容
Garmin Drive 52 and Traffic Battery Replacement
你所需要的
  1. Garmin Drive 52 and Traffic Battery Replacement, Battery: 步骤 1 中的图像 1,3 Garmin Drive 52 and Traffic Battery Replacement, Battery: 步骤 1 中的图像 2,3 Garmin Drive 52 and Traffic Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a T5 Torx screwdriver to remove the four screws in the corners of the backside of the device.
    • If necessary, use a Jimmy or other pry tool to open the backside of the device.
  2. Garmin Drive 52 and Traffic Battery Replacement: 步骤 2 中的图像 1,3 Garmin Drive 52 and Traffic Battery Replacement: 步骤 2 中的图像 2,3 Garmin Drive 52 and Traffic Battery Replacement: 步骤 2 中的图像 3,3
    • Once the back side is open, flip the ZIF connector's lock bar up then remove the connector.
  3. Garmin Drive 52 and Traffic Battery Replacement: 步骤 3 中的图像 1,3 Garmin Drive 52 and Traffic Battery Replacement: 步骤 3 中的图像 2,3 Garmin Drive 52 and Traffic Battery Replacement: 步骤 3 中的图像 3,3
    • Use a T5 Torx screwdriver to unscrew the four screws securing the motherboard.
    • Gently detach the wiring from the motherboard and left the motherboard out.
    • Use a nylon spudger to gently lift the battery out.
    • Avoid using metal spudgers near batteries; puncturing or excessively warping batteries can be dangerous.
结论
2等其他人完成本指南。
Jason Wilson
于10/26/22注册
388 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-2, Petersen Fall 2022 UMass Dartmouth, Team 1-2, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S1G2
6 名成员
创作了4篇指南
一条评论
Guide is great. Step by step.
At the end you could probably forgo taking out the motherboard, but better safe than sorry. Only hard part was re-attaching the screen to the zip connector again. Small space, used a flat spidger to flip the zip connector down once I had the connector strip in place.
Thank you for this guide saved me $140 on a GPS.
Chris Massey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 57
总计 930
