跳转到主内容
Garmin Dezl 770LMT Battery Replacement
你所需要的
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: 步骤 1 中的图像 1,2 Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: 步骤 1 中的图像 2,2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: 步骤 2 中的图像 1,1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: 步骤 3 中的图像 1,1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: 步骤 4 中的图像 1,3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: 步骤 4 中的图像 2,3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: 步骤 4 中的图像 3,3
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: 步骤 5 中的图像 1,2 Garmin Dezl 770LMT Battery Replacement: 步骤 5 中的图像 2,2
    • Grasp the wire near the mother board and gently lift to detach the battery.
结论
5等其他人完成本指南。
团队
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 的会员
USFT-LACY-F16S1G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 6,107
