跳转到主内容
Garmin Dezl 760LMT Screen Replacement
你所需要的
  1. Garmin Dezl 760LMT Screen Replacement, Back Panel: 步骤 1 中的图像 1,2 Garmin Dezl 760LMT Screen Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Screen Replacement: 步骤 2 中的图像 1,3 Garmin Dezl 760LMT Screen Replacement: 步骤 2 中的图像 2,3 Garmin Dezl 760LMT Screen Replacement: 步骤 2 中的图像 3,3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Screen Replacement: 步骤 3 中的图像 1,1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: 步骤 4 中的图像 1,2 Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: 步骤 4 中的图像 2,2
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Screen Replacement: 步骤 5 中的图像 1,2 Garmin Dezl 760LMT Screen Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Screen Replacement, Screen: 步骤 6 中的图像 1,2 Garmin Dezl 760LMT Screen Replacement, Screen: 步骤 6 中的图像 2,2
    • Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
  7. Garmin Dezl 760LMT Screen Replacement: 步骤 7 中的图像 1,3 Garmin Dezl 760LMT Screen Replacement: 步骤 7 中的图像 2,3 Garmin Dezl 760LMT Screen Replacement: 步骤 7 中的图像 3,3
    • Turn the screen over so that it is facing upwards.
    • Remove the front plate of the screen.
    • Lift the screen from its back casing.
结论
Ryan Williams
于09/28/16注册
763 声望
创作了6篇指南
团队
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G2
4 名成员
创作了6篇指南
2条评论
where can one by the replacement screen
tempestrogue - 回复
Ebay sells these screens replacement - search online for “ZD070NA-03K “ or on google, even amazon sometimes has them. Its a hard to find screen so you will probably only get it from hong kong or china.
neilneves - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 2,304
